oil smell come threw the vents
    i have a 92 accord lx when i turn on the heater when im driving the oil smell comes threw the vents and ut start to blow cold air when the heat is on does anyone know what it could be?
    oil smell i can't help you with
    but the cold air through the heater, check coolant level first then your water valve
      Yeah I was thinking maybe the water valve is causing the cold air. Also is there oil leaks that could be getting sucked in by the fans and causing that smell?
        i checked and did not find any leaks thats the first thing i checked for
          you spill oil in the engine bay recently? i changed oil in my tranny the other day and my clumsy girl friend spilled a bunch of oil over the head, since then I've been getting an oil smell through the heater, but its wearing off.
          Everyday is one day closer to completing my cb7 <3
            What's a water valve.
              its the valve that controls the flow of water to the heater core
                na it always smelled like that since i brought the car
