my floor carpet of the passanger is always wet
    i fix my front windshield but my car is still get wet inside the passanger floor.what can i check??
    paypal info:leonardorivera50@yahoo.com
    It could be water from evaporator. Clogged/dislodged drain tube,,,
    A&P-IA
      Your heater core maybe leaking. Is your coolant level seem to be going down? Are you positive you got the windshield leak fixed? I had one on a car once that took a couple tries to finally fix it.
      http://www.cb7tuner.com/vbb/showthread.php?t=178069
        If it's heater core, you would smell it.
        A&P-IA
          where do i see this on the car?
          i fix i got a brand new winshield,my cooland is good its smells like nasty water no cooland
          yeah i knw
            I don't know where that tube located. But if I need to know I would check/study a service manual for the car. There is online site for free down load for such service manual. There may be a link for it on this site/forum.
            A&P-IA
              Read this http://http://www.cb7tuner.com/vbb/showthread.php?t=167767&highlight=leak
                i will thanks
                Originally posted by ugafan001 View Post
                thank you it dnt work
                  my bad try it again. An unless you use your ac in the winter i doubt its that. But the ac line rubs out the fiewall on passenger side and down under car
                    thank you
