My car have the o2 sensor but the wires are cutted and I don't have any idea where's the plug. I guess, this detail explains the bad gas consumption. My heart is an f22b but the car is a 90 LX. Please help. Thanks.
O2 sensor plug
Is your o2 sensor hooked up (as in, are the wires spliced together?)
If not, then yes, that would be your issue. I assume you didn't do this swap yourself, or else you'd know what was done. The plug should not have been cut off... that can result in a change in resistance, making even a good sensor read improperly. Too late now, unfortunately.
Depending on which F22B you have (SOHC or DOHC), and what exhaust manifold/header you have, the o2 sensor may not be in the same location that your stock one was supposed to be.
This is the situation:
And this is the only plug empty, it's besides the shift and lock solenoids plugs, I mean, they're all taped together: I don't know if it's from the o2 sensor.
And yes, I bought the car with the swap. It's a f22b1 vtec (to be more specific). It's stock, at least the manifold. And that reading problem/resistance situation results in having to buy another ECU, or there's any hope?Last edited by F22BPR; 02-18-2012, 09:34 PM.
That looks like an O2 plug. Your LX originally had the O2 sensor located on the front of the bottom of the exhaust manifold and its harness would reach to where that plug is. The O2 sensor now on your car is in the flex pipe just ahead of the catalytic converter similar to where it is located in an EX.
Couple ways to go:
1. Get a connector from a junkyard 02 sensor and additional wiring to splice to the sensor in your car.
2. Or what I did with my 90. I installed flex pipe from my EX and an F22A4 manifold (entirely new flex pipe on EX, had flex section welded on the old Y pipe for the 90). I spliced together a jumper harness made from the wires and connector from another sensor and a section from another engine wiring harness to be able to connect from my engine harness down to the new sensor location. Runs fine so far. If you do this, you would need another 02 sensor with the connector on it.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Either way, you'll need more wire unless you can undo the current engine harness enough to allow you to pull the existing plug back far enough to connect to the sensor plug (if you get one with a plug). I tried undoing mine, buy went the jumper harness route becuase I had an old sensor around and had cut a section of engine harness during a trip to the junkyard.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
I was looking this thread...
http://www.cb7tuner.com/vbb/showthread.php?t=179204
But I need just the female plug, more wiring, and jump it to the o2 then. Right?
