How to lube front sway endlink bushings before install??
    Hey everyone! I purchased the energy suspension front sway endlinks and am about to replace them, but I was looking at the DIY for that and noticed the kit comes a lube. Mine didn't come with that, so I was wondering what would work just the same? I have some vaseline lol. Any advice is appreciated.
    Vaseline or regular automotive grease will NOT work. It will end up washing off or deteriorating the poly. You need to either order some of the grease that is supposed to be used or rumor has it marine grease will work.
    In a pinch, you can try using silicone grease, but it will probably wash off rather quickly in the rain.
      If you dont mind a little noise, you dont have to use any. Vaseline wont work except maybe with installing them, theyll still be squeaky.
      Graphite grease or the permatex brake ceramic or synthetic grease works, or acquire some of the bushing lube which is sticky and doesnt dissolve away as fast as others.
        Graphite has been durable in other applications for me in the past.
          Thanks for the info guys. Ill try to locate some graphite grease
