my temp gauge not operating correctly
    i had this problem since i bought the car about 2 months go but had other major problems to fix ( not being able to shift, burned out dizzy, broken exhaust est.) , my car does not seem to over heat and the fan kicks in periodically like its suppose to, but my temp gauge does not read correctly. when im driving and hit bump it fall back down from running temp to cold. and some time it just goes up and down , does anybody have an idea of whats causing this ?
    There are two separate temp probes, one for running cooling fan and the other for coolant temp indication. Check the condition of wire for temp indication. It sounds like your car has intermittent connection there.
    A&P-IA
      mine did the same, so i put in an aftermarket and problems gone
        Put in an aftermarket what? Sensor? Gauge?
        I would agree with Oyajicool, you most likely have a loose connection at the temperature sender, which is located in the general viscinity of the thermostat.
          I Bought An Electrical Temp Gauge From Autozone And In The Kit Came With Everything U Need(sensor,fittings) For About $14.00 Had On Over A Year And Hsnt Failed Me Yet
            ok will cheak that later today and update u guys, thanks
