clutch driving me nutzz
This topic is closed.
    So I recently too my wagon to a mechanic to set all the sensors and make sure my idle got straightened out. Which he did an awesome job at it , but somehow he said my clutch was to high so he adjusted the pedal for me . When I picked it up everything was fine so I drove it home (45 min drive) and as I was driving my clutch was feeling funny kind of like if it had 3 different stages of clutch pressure 1 almost all the way down than it only needed just a tap to change gears ,2 all the pedal all the way out to grab gears and 3rd a lovely clutch no problems at all ,so I called him and ask him about it he said that he didn't mess with the pumps at all that it was weird so I told him that I would go back to get that fix.Next day morning my clutch was all the way down and I wouldnt go in gear so I had to bleed it and it had a shit load of air so I got to take it back he bleed it again and everything seemed fine so I took it home and the same problem again . I looks like my car is getting air in the lines as I drive so I going nutz cuz I have to bleed it daily. The clutch master is about a month old and slave cylinder too so I DON'T have a leak at all cuz it never needs fluid . So today I decided to take the reservoir out to see if it was crack or anything and notice the line from the reservoir to the master was wet in the tip so I cut it off thinking that could be my problem and I blew air to the reservoir through the the tip of it and air comes out through the cap ,is that normal for air to come out a close reservoir when blowing through the fitter . Does anyone know what can be wrong with my clutch cuz I don't as always have someone when bleeding it and that's my DD .any help please I hope I explained it good enough thanks
    Come on pleople help me with my situation!!
      sounds like there is an internal leak in your master cylinder. You said you just changed it but it may have been defective.
      92ex CB7<-SOLD 93ex CB9shiftingshift73C10
        You are impatient. Problem fixed.
