Dizzy was leaking oil now clutch chatter
    Hi my accord 91' has some clutch chatter I've been living with it for over a year now but its getting old. When I first take off in the morning it chatters bad. What I normally do is burn the clutch a little. I'll take of in 3 or something, then its all set. My only question is will this keep happening until I change the clutch? or is there a way to fix it without dropping the tranny?
    There are some days that it has no problems at all. It drives as smooth as can be.
    1991 Honda Accord 2DR LX 180,000 Miles RIP
    That chattering may be due to glazing on flywheel. The flywheel needs inspection and resurface/replacement as needed. It is a good idea that clutch assembly also be replaced at the same time.
    A&P-IA
