jdm h22 or usdm h22
    jdm h22 or usdm h22
    whats up guys, i have a usdm h22 block, and i wanted to know is it worth putting on an jdm h22 head, and whats the difference between the two, i plan on sleeving the block an getting pistion!
    Unless it is a Type S which has the better camshaft profile, don't bother prolonging your build. The heads are identical.
    '94 JDM H22A: 178whp 146wtq
      There may be some minor camshaft differences, but those will be changed anyway if you're doing a real build. The castings will be the same. An H22A head is an H22A head as far as you need to be concerned.
        Thanx, so I'm going to keep the usdm block
