So my brother bought a jdm f22b dohc a few years ago that he planned to put in his accord. Plans changed and it is now mine. I threw some wd40 in the cylinders to try and hand crank it and snapped a socket clean in half.It has been sitting in a shed in humid Miami so I fear its siezed what's 5he best way to "unsieze" I have some pb bolt blaster in the cylinders now to loosen it up. Hopefully I didn't just buy a 300 dollar paper wieght
engine help
WD40 isn't really intended to be a lubricant. Probably not the best thing to put in there.
If the internals have corroded to the point of being seized, then they're most likely shot. If you get it moving again, it's highly likely that it will burn oil like crazy, and it may spin a bearing very quickly.
Well if the motor is seized is it a good idea to use parts from it and swap them to my f22a1 stuff like head and intake Mani? 2ould there be any gain or should I just save my pennies for something else?
Edit: just found a thread by. CbAccordA4 who swapped the head. Seems like that's what i may doLast edited by lowcb7; 02-14-2012, 04:41 AM.
50/50 of ATF and acetone works good as penetrant, but in this case, I would use a 50/50 mixture of engine oil and Marvel Mystery oil.
Drain old oil.
Pour mixture into cylinders through plug holes.
Pour mixture onto valve train.
Leave it over night.
Try turn engine by hand. If it turns you are lucky. If it doesn't, you may apply some more of mixture and leave it for another night.
Try turn engine by hand. If it doesn't turn, it may be time to disassemble the engine and see what is stuck/not moving.
Repair as needed. Or use good parts for other application/engine.A&P-IA
Originally posted by oyajicool View Post50/50 of ATF and acetone works good as penetrant, but in this case, I would use a 50/50 mixture of engine oil and Marvel Mystery oil.
Drain old oil.
Repair as needed. Or use good parts or other application/engine.
Plug holes? Those are called freeze plugs. Those are for the coolant in-case it freezes so it wont crack the block. So it can expand when it freezes without cracking the block. The coolant jacket runs outside the cylinder, so adding anything into there would be pointless.
Theres no other "hole" going into the cylinder. You can pour on top of the pistons or the bottom through the crankcase. Theres no other access into the cylinder though.Originally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by cb7_tillidie View PostHe means the spark plug hole I think.
LolololOriginally posted by wed3kim a douchebag to people and i don't even own a lambo. whats your point? we, douchbags, come in all sorts of shapes and colours.
Originally posted by deevergote View PostThat head is one of the few that's actually decent to swap to an F22A. It's really not that much better, other than the fact that it has two cams. You'll get a 5-10hp bump at most, and half of that will be due to the manifolds.
Edit :what's the difference betweeen f22ax blocks and the f22b
Drain old oil.
the blocks are nearly identical, though the F22B has higher compression. It's only 20-26hp difference from the F22A6 (the F22B was reputed to make 160hp for the longest time... this 166hp rating is something new, and I'm not sure how valid it is.)
I'm sure some of the added compression is due to the head. However, I am assuming that the pistons are different as well.
To be honest, if you want to do a build, there's really no reason to even use the F22B head. The F22A head is perfectly capable, and all the parts you need for it are readily accessible in the US.
Originally posted by deevergote View Postthe blocks are nearly identical, though the F22B has higher compression. It's only 20-26hp difference from the F22A6 (the F22B was reputed to make 160hp for the longest time... this 166hp rating is something new, and I'm not sure how valid it is.)
