I've been having a map sensor problem for a while. Finally took it to a buddy of mine who has the same swap and exact setup. Wired it just like his, apprearntly, they had bypassed a valve or something, its on the bottom left of the intake manifold, right before the pipe of the intake connects, they had put the two hoses directly to each other. We started the car up, ran grreat, no hesitation, and it was moving really good. Went home, parked for like an hour and half, went back. I took off, and after about 400m the car started to "hold back again" but was dramatically worst.
now its popping through the exhaust and intake, intake popping is louder than the exhaust, it sounds like popcorn popping. It was 2am when this happened, so I pushed the car to a friends house and parked it on the road. I dont know where to start, other than undoing what we did. But besides that, some things it did just before the engine cut off was the speedo acting up, and the rpm guage did not budge, and eventually the speedo just stopped moving.
the car will not turn over, i have to push start it to get it going and it will not stay on unless i am reving the engine.
This happened the night before on a cold start, but went away with time once it got warm. I rely on my car for work, which i should be at now but cant cause i work 45 mins away by highway. Any input on where to start or what could be wrong would be great!!!!!!!!!!!!!!
please keep in mind i have a h22a1 with 5 speed transmission
