Hello guys,
I don't know where and what cause the noise but it's not clunking, not moan or groan, not thumping. This occurs when hitting small little pot holes and bumps. I avoid as best I could all of the big holes, and almost come to a stop and climb slowly over big speed bumps or any bumps if I could. What can I say, the car is old and don't it falling apart when I am unemployed and cannot afford to fix it.
The noise is symmetric, higher up under the hood and I don't really know what to call it other than it's like little chattering clicking when hitting tiny bumps or holes.
My upper and lower control ball joints are good, no play in the rack and no leak at all.
When I just got the car almost 4 years ago and I took the car for alignment after new tires, the mechanic said the sound is from worn out shock. Now I know my shocks are not busted. There's no bouncing when hitting big bumps and if I push my car down it does not bounce up and down like my old dancing 87 Corolla.
What do you guys think? The strut mounts are worn out you think and thus making that chattering noise?
Now I want to grease my upper control arm and bushings, what kind of grease should I use and how would I do it? I replaced my upper control arm and outer tie rod boots about 2 years ago and I grease them up good with the red Harbor Freight grease. http://www.harborfreight.com/14-oz-s...ase-40710.html
If I want to regrease the boots in the future, what technique would you guys recommend that I do? I hate taking the boots off again and taking the circlips off to regrease.
Thanks.
Thanks.
