20w50 oil grade
This topic is closed.
    20w50 oil grade
    Hi All
    Will 20w50 harm my f22a1? Thanks in Advance
    I have 170000 miles on it. When I use 5w30 the oil only lasts about a week before it turns dark.
    Someone offered me some free oil, but it is 20w50 grade.
    Why do you need oil that thick? 10W-40 is the most I would recommend for H22s with oil leaks. For your F22, unless you're making 400whp+ which I know you aren't stick, with stock weight. While I'm not perfectly sure, I have a hunch that would kill your oil pressure and somehow harm the engine.
    '94 JDM H22A: 178whp 146wtq
    If you say double dutch rudder, i'm banning you...
      That seems a bit heavy, but then again im no expert. I run 10w30 every oil change and it hasn't done me wrong yet. I don't think it would harm your motor but it probably won't do any good. It also might take a minute to reach your head on a cold day though. I say this because im pretty sure that is a really heavy/thick oil. Anyway just give it a minute and someone with much better advice will chime in.
      EDIT: Joey GT-R beat me haha
        Like i told you in your other thread a thicker weight oil is a damn BAND-AID it wil not fix your issue in the long run. The oil sending unit is less than $20 why not try a new one out?
        Like talking to a brick wall with some of our members. Why ask questions if you're going to take the rigged way out?
        02 Crv
          Haha you need to have more patience when reading threads. I asked because since the oil was being offered to me, I figured id ask before even accepting to receive it. Smh
            Fine, take it. His next thread: "Cheap Engines to Swap in for More Power"
              "Cheap Engines to Swap in for More Power Preferably for FREE."
              I wouldn't run thicker oil, even if it was given to me.
                No shit i tried and gave what i thought was good information and check list on his first thread. Hey if they don't listen an use common sense then good luck to them.
                02 Crv
                  Ever think why the oil is free?
                  wat?
                    Whoa! Totally didn't go through how it was supposed. I definatley appreciate the advice.
