Battery light blinking
    Hi to all,
    Well i don't know why, but my battery light have an intermittent blinking.
    Anyone had this issue before?
    Thanks
    Check your alternator to see if its over or undercharging, you should be able to have a local parts store check your charging system for free. Also pop the hood and make sure you still have your alternator belt.
      I had a similar problem. I had it checked at Advance and Oreily's and they said the alternator was okay. After I got tired of the light intermittingly blinking, I put another alternator on. Problem was fixed.
      http://www.cb7tuner.com/vbb/showthread.php?t=178069
        I would make sure the charging voltage is within the limits, 13.95 to 14.4VDC, with loads, before changing alternator.
        A&P-IA
          Make sure alt belt is tight
          My whips so clean I can see the reflection of your car in the reflection of my car on the reflection of your car
            In your case, it was the regulator on the alternator. I had my battery light on and every place I took my car to for an alternator test, they said it was good. So I bought a used alternator on Ebay, OEM Honda, took the regulator out and put it on my current one. Light goes off. I did it without even removing my alternator. I also checked my belt first. While you are in there, might just well replace the brush kit.
            Good luck.
