Low Idle
    Low Idle
    this started happening, i read the topic about adjusting idle..every now and then it drops even lower. oil light is not coming on.
    what my question is, is what would cause this ? is it any reason for concern ?
    Jesus drove a Honda, he just didnt talk about it like us. Proof - John 12:49 "For i did not speak of my own accord."
    den das al u ned u no dat u get wurs gas milge tho rite?
    Anyone ?
      BUMP!!!! I have the same problem......
      Originally posted by wed3k
      are you serious? thats like blaming the rubber because you didn't get the right size for your dick.
        i had this problem,along with little glitches with my interior lights,in the end it was my alternator,changed that and my intermittent low idle problems stoped.
          I see your Engine light is on, could be something with that? does it idle hard too?
            clean iacv and throttle body and set your base idle and see if that helps, also u may have a vaccum leak that could be causeing the problem
              Everything what said above.
              But maybe it's vacuum lines are blocked. I mean If outside air temperature where you are is low, I mean under 0 degress C, than vacuum lines can shrink more than usual and if you have dirt in it, lines will be blocked.
              Just suggesting to check lines and maybe change it. After all we drive 20 years old car.
                i had same issue . ended up changeing all my vacuum lines . they where cloged or broken .
                Car safety checks
                Fluid Capacities
                  honestly its not that low, OEM spec is 750. if it's dropping below 700 i would check your IACV, use a multimeter there should be between 8-15ohms of resistance. if it's outside that, or won't hold a constant reading it's bad. replace it.
                    I'm running my f22a6 there @750 ,starting to notice surging idle at start up , and check light when I go over a bump ( think its becouse I red necked my o2 )
                    Originally posted by evil_demon_01
                    Do it once, do it right.
                    Saving a dollar is not worth risking a life.
                    Missing My
                    White -91 LX Sedan - leather converted
                    Mulberry 91 EX Sedan
                    The project 92
