F22ax N/a newb questions
    Est. on the cost of the k24+k20 pistons build? Doesnt sound terribly difficult and or expensive?
      id rather spend the money on forged 12:1 pistons then youll really make use of the cam. otherwise, stick to a budget and stop dreaming.
      i just built my friend's thunderbird motor and he's into it about 13k in just parts. it turned to just doing the upper end to a fully built race motor. hes now out of money and living on credit trying to support two kids and a wife.
      stick to a budget, dont be cheap and spend where it is needed.
        Take that $1k and buy yourself: HF mani, 14B, 450's....etc and turbo your D16. Done and Done. 170WHP from a turbo D16 is NOT hard or terribly expensive.
          oops sorry didnt see that you already posted that, so 500 inc labor for the machining? plus cams and a clean up of the head ftw 180 whp.
          Again thank you for all the answers to my seaming less noooob questions
            If you can't do the work yourself then cost will only go up. I'm with Wed3k though start small since you're new bolt ons maybe a cam and a proper tune 150whp with greater or matching tq in a eg will move along just fine.
            02 Crv
              What I meant for labor is the machining of the parts, I can do all the assembly and work my self. I just meant the machining.
              Thanks for every thing!
              Im going to start the build in about 2 weeks Ill post pictures etc soon!
                I would stick with parts specifically made for your application, unless you have considerable experience working with these motors (which you clearly do not, or you wouldn't be asking!)
