Leaking oil cooler
    Leaking oil cooler
    Okay so my car has started to leak after Alot of under the car looks and wipes and so on I found out my oil cooler gasket ? Is leaking I need to know if there is a gasket for the f22a1 engine in there or how it's sealed it leaks on my exaust mani and smokes bad the other thing it does is overheats at drive threws when I'm stopped in neutral but no other time any ideas thanks
    Originally posted by evil_demon_01
    Do it once, do it right.
    Saving a dollar is not worth risking a life.
    Missing My
    White -91 LX Sedan - leather converted
    Mulberry 91 EX Sedan
    The project 92
    The F22A1 does not have an oil cooler, that's on the F22A6. Most likely if it's not leaking from your oil filter it's leaking from the oil pressure sensor. It is located directly above the oil filter, there's a black cover on it with one wire going to it. If you look at the top of the picture you will see a gold plug in the block, on the side of the block under that is the oil pressure sensor.
    And the reason you overheat at lights is most likely a failing water pump.
