ok i have a weird problem. 92 accord is white smokeing bad when you give it gas a then sometimes not so bad. when it is just idle.... i have done all checks to see if maybe the head gasket is blown . my oil doesnt look milky and nothing under the oil cap.. and the car is not overheating or as far as i know not burning any coolant.....any suggestions
white smoke
Originally posted by ichibahn View Postok i have a weird problem. 92 accord is white smokeing bad when you give it gas a then sometimes not so bad. when it is just idle.... i have done all checks to see if maybe the head gasket is blown . my oil doesnt look milky and nothing under the oil cap.. and the car is not overheating or as far as i know not burning any coolant.....any suggestionsthis was put together by evil_demon_01 . You can also fined all this and more by him in the Common Beginner Technical Info can be found in here. PLEASE READ HERE FIRST
Car safety checks
Fluid Capacities
Smell the smoke. Does it smell sweet? If so, it's coolant.
If not, it's probably just condensation. Every winter, we get a flood of "OMG my head gasket is blown helppppp!!!" threads, and all people are seeing is the steam escaping from the exhaust pipe as the condensation that collected in it overnight burns off.
Originally posted by deevergote View PostSmell the smoke. Does it smell sweet? If so, it's coolant.
If not, it's probably just condensation. Every winter, we get a flood of "OMG my head gasket is blown helppppp!!!" threads, and all people are seeing is the steam escaping from the exhaust pipe as the condensation that collected in it overnight burns off.'94 CD5 EX F22B1 Automatic
Originally posted by deevergote View PostSmoking "hella bad" isn't normal. There's a difference between steam and smoke. If it's actually smoke, something is wrong.
