my brothers automotive teacher has a good b20 that he wants to get rid of... just wanted to ask would a b20 bolt in an if so whats the difference gunna be rather than the f22a1 let me know asap thanks all
b20 in a 91 lx with trans
i have a f22a1 with a 146k on it an its the non vtec b20 i can get it for 250 his teacher just pulled it runs great everything but just need to know if it would be with it an i know it will pull the cb pretty good have the torque for sure considering its from an suv but how much work just askign
Originally posted by hondafreak2012 View Posti have a f22a1 with a 146k on it an its the non vtec b20 i can get it for 250 his teacher just pulled it runs great everything but just need to know if it would be with it an i know it will pull the cb pretty good have the torque for sure considering its from an suv but how much work just askign
The amount of work and custom fabrication necessary to use a B20 in an Accord would not be worth the final result. Custom mounts, custom axles, custom wiring, custom ECU (the CRV is OBD2, so there will be no compatible "plug in" ECU without rewiring the entire car.) Also, the B series uses a transmission that is shifted with rods, not cables as in the Accord... therefore you'd need to hack up your floor pretty good to accommodate the rods.
The engine has plenty of power, and would move the car just fine.
And no, you do not see B20 VTECs everywhere. The B20 is a non-VTEC engine.
Because they have a vtec head swap from a b16,GSR, or ITR .No B20 came from the factory with vtec.
And the b20 is a pointless swap for this chassi it would take alot of money and fab to get it to actually work in a CB.
02 Crv
Originally posted by deevergote View PostThe amount of work and custom fabrication necessary to use a B20 in an Accord would not be worth the final result. Custom mounts, custom axles, custom wiring, custom ECU (the CRV is OBD2, so there will be no compatible "plug in" ECU without rewiring the entire car.) Also, the B series uses a transmission that is shifted with rods, not cables as in the Accord... therefore you'd need to hack up your floor pretty good to accommodate the rods.
How much power would a b18/b18 head on a b20 make?
Originally posted by deevergote View Post"chassis". The last "s" is silent, but it is still part of the word. "chassi" isn't a word.
(sorry... I see that everywhere, and it bugs the shit outta me.)Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
A straight LS head from a b18 will not make much if any difference, but a healthy LSV or B20V will make 160-170whp once tuned also depends on the head.
02 Crv
Yeah, it's hard to say how much power you'd get with a headswap. It's a very popular swap among the Civic/Integra crowd. I don't know enough about B/D series headswaps to condemn them the way I do H/F headswaps, so I'll just assume it's a good thing.
Still, any B/D series engine is worthless to us. The cost is way too high, unless you're damn good at fabricating... in which case, you could probably stuff a better engine in there. The ONLY reason to do such a swap would simply be for the ability to say you did it. It would indeed be different.
