b20 in a 91 lx with trans
    my brothers automotive teacher has a good b20 that he wants to get rid of... just wanted to ask would a b20 bolt in an if so whats the difference gunna be rather than the f22a1 let me know asap thanks all
    That would be a lot of work. And I don't believe they have the torque or the power to move the bigger accord.
      A b20 comes in a CRV, it definitely will move the cb. It would be too much work to gain a whole 1-20hp depending on which b20 it is and which F22a you currently have.
        i have a f22a1 with a 146k on it an its the non vtec b20 i can get it for 250 his teacher just pulled it runs great everything but just need to know if it would be with it an i know it will pull the cb pretty good have the torque for sure considering its from an suv but how much work just askign
          There is no such thing as an OEM B20 VTEC....... It is still not going to be worth it. All the work you would need to fab up is too much effort for a whole 20hp max.
            as i said non vtec and i see b20 vtecs all over...
              The amount of work and custom fabrication necessary to use a B20 in an Accord would not be worth the final result. Custom mounts, custom axles, custom wiring, custom ECU (the CRV is OBD2, so there will be no compatible "plug in" ECU without rewiring the entire car.) Also, the B series uses a transmission that is shifted with rods, not cables as in the Accord... therefore you'd need to hack up your floor pretty good to accommodate the rods.
              The engine has plenty of power, and would move the car just fine.
              And no, you do not see B20 VTECs everywhere. The B20 is a non-VTEC engine.
                What car does a b20 vtec come from? I know that the B20's in 1st gen CRVs is a non vtec.
                  Because they have a vtec head swap from a b16,GSR, or ITR .No B20 came from the factory with vtec.
                  And the b20 is a pointless swap for this chassi it would take alot of money and fab to get it to actually work in a CB.
                  02 Crv
                    Those are B20 Franks, not OEM.
                      "chassis". The last "s" is silent, but it is still part of the word. "chassi" isn't a word.
                      (sorry... I see that everywhere, and it bugs the shit outta me.)
                        I knew that there was no such thing as a b20 vtec without doing a head swap.
                        How much power would a b18/b18 head on a b20 make?
                          Blame it on the damn French!
                            A straight LS head from a b18 will not make much if any difference, but a healthy LSV or B20V will make 160-170whp once tuned also depends on the head.
                            02 Crv
                              Yeah, it's hard to say how much power you'd get with a headswap. It's a very popular swap among the Civic/Integra crowd. I don't know enough about B/D series headswaps to condemn them the way I do H/F headswaps, so I'll just assume it's a good thing.
                              Still, any B/D series engine is worthless to us. The cost is way too high, unless you're damn good at fabricating... in which case, you could probably stuff a better engine in there. The ONLY reason to do such a swap would simply be for the ability to say you did it. It would indeed be different.
