Has any one heard of this engine befor?
    AKA glow plugs.
    This engine is cool to talk about and all, but IMO worthless here in the states as parts would hard to find.As for you (the OP) i don't see you flipping this, it will be hard to get rid of.Use that 1k on suspension and get rid of that ebay junk you just bought.
    02 Crv
      Originally posted by flatrex View Post
      Ugh I didn't plagiarize anything I simply copied it from an app on my phone, since this is a thread regarding this engine I figured it would be good info. You are the second moderator giving me crap for that post so if its such an issue just delete it, it wont bother me.
      copy and paste is plagiarizing friend lol
      The Facebook group
        <-- not a moderator.
          Copy and pasting something is plagiarism if you don't list a source. Also, Deev isn't a mod., he's the site owner. Huge difference.
          I don't know a single thing about mechanics, but I can take anything apart and put it back together from memory.
            Originally posted by SOHC-FTW View Post
            AKA glow plugs.
            Well I did my taxis today so I sold thoughs springs to some crack head. This is what I plan to do. Im going to invest 2k in my suspension . Then put the rest of the 4k away to save
            Up for my 8k f22a build. Since the info you guys gave to proves there will be no profit.
            Car safety checks
            Fluid Capacities
              Originally posted by Accord problems View Post
              So I shudint waste my time on it? Saying if you where me.
              get the motor
              build a 4 ft by 4 ft tube frame for the mounts
              custom tube with a flange to bolt to the crank end
              hook it to a large generator
              drop the electric company
                The N series is Honda's first diesel engine. It is a four-cylinder common-rail diesel engine for medium-sized Honda vehicles. It features the ubiquitous Common-Rail Direct Injection configuration which Honda brands as their i-CTDi (Intelligent Commonrail Turbocharged Direct injection). The most notable feature is the aluminum block, which uses proprietary technology to the manufacturing process of the cylinder block, and provides both light weight and high rigidity. The valvetrain is a DOHC style with chain-driven camshafts. The Fuel System is a high-pressure (1600bar) Common rail direct injection type with a variable geometry turbocharger with intercooler.Max boost pressure 13.5 psi
                Copied from Honda automotive database app
                There you guys happy now.....don't go calling sopa and pipa on me
                My whips so clean I can see the reflection of your car in the reflection of my car on the reflection of your car
                  The SOPA and PIPA bills both failed...
                    It was a joke...... bit they have a child pornography bill coming that will have all the sopa and pipa stuff tied into to it, but that's a completely different discussion that has nothing to do with information on the N series Honda engine.......................................
                      8K F22A Build? If it's not at least a 2.5L making 500whp then you failed :-P But good luck tho.
                      '94 JDM H22A: 178whp 146wtq
                        Even Bisi's F doesn't make that sort of power...
                        $8,000 into an N/A F22A that is built PROPERLY will have the potential to make 250-300whp. At the 250whp mark, it will become almost unbearable to drive on the street.
                        $8000 into a turbo build could easily make 600whp.
                          I was thinkin turbo. But I think 300whp should still be streetable.....
                            This isn't a "what are my options" thread... and PLEASE don't go around suggesting an engine that you yourself know next to nothing about. We don't need any more kids on the internet regurgitating what they read on a forum somewhere without actually understanding what they're saying. There's too much of that going around already.
                            Alright, I'm sorry. I'll stop and I guess you have a good point. The only thing I know about the H23A is that it has the H23 block with a modified H22A head. And I think it has a lower redline. So yeah, I agree with the fact I know next to nothing
                            Sorry for bothering you about that, it won't happen again
                            1993 Honda Accord EX
                              Ill be pulling the motor out and apart . I will have two weeks to rebuild it. the third piston broke . I will have two weeks of down time On the 8 th of next moth.
                              Car safety checks
                              Fluid Capacities
                                Compression ratio: 16.7:1
                                ^^^^^^^^^^^^^^^^ some totally different comp ratios
                                "If you're going to put money into a car to increase performance or appearance, why go cheap? People don't need to go all-out... but put a little effort into it, or don't bother doing it at all"-Deeve
                                Ride http://www.cb7tuner.com/vbb/showthread.php?t=187088
