suspension
    suspension
    Is the stock prelude suspension comparable with my 90 Lx. Found stock complete set of strut springs and.if so is there any difference from stock accord setup?
    No. The only suspension that you should be using is one made for a 90-97 (4cyl) Honda Accord.
      What year prelude?
      92-96 prelude difference that I know is that the prelude suspension is lowers than accords.
      "My FOR SALE thread - Click here"
      MEMBERS RIDE
      99 SILVERADO
      WHEEL FLIP
          Thanks for all the responses however I'm trying to replace me current setup of cut springs and blown shocks. And I can get a prelude set for a killer price. The.junkyard nearest to me is owned by a crook who everprices everything. I believe running on prelude shock would he much safer that what I currently have so all I'm really asking is whether the bolt up pattern and assembly is the same
            I don't believe the shocks will bolt up. If they do, it will be just the front, or just the rear... I forget which supposedly fits. They won't be valved correctly for the Accord. They'll still be safer than blown stuff, but not much. You could probably use the springs, but I wouldn't. If the diameter is different, they won't seat properly. If you can get Prelude parts cheap, grab em and resell em on ebay, craigslist, or a Prelude forum. Make a profit on them, and put that money into buying proper accord parts.
            Get 30 posts, and you'll be able to enter the Classifieds section of this forum. There, you can request stock springs, and someone may have them to sell to you. Someone may even offer to give them to you, as they're not really of any value to anyone. With stock springs, your cheap shock options are abundant. KYB GR2 or Tokico HP are good, and a very mild performance upgrade (neither is good for a drop, but good for OEM springs.) Even crap like Monroe or Gabriel will be sufficient. They're not good, but a hell of a lot better than what you have!
              Thanks for the input deev. What the differnce between 90-93 strut/spring and 94-97 stuff. Like ride height and comfort
                It's all pretty much the same. I think the main difference may be the valving of the shocks... but that may not be the case either. Most aftermarket stuff is the same between 90 and 97.
                  I found stock 94-97 stuff for 120 on Craigslist didn't know I that good a good deal or not
                    $120 seems a bit steep if it's old original stuff... but it'll fit if it's worth that price to you.
