Battery Dying, autozone says its good??
    Well i bought a new battery with warranty from autozone, lasted a couple days and it died, completely. Then i took to autozone to check it out, they said it needed charging, so they charged it for one hour, said battery is good. Put the battery back and the car started right away, still starts now but barely, battery is dying again, once its running it runs with fine. Could it be my alternator? or something else?
    i noticed the negative cable has a extra cable going to the fenderwall, that cable is broken, could that be the problem?
    view my ride: My Ride
    Sounds like a ground came loose or broke, from what you were describing. Check that first.
      Sounds like your car is killing the battery.
      wat?
        That little ground that is going to the fender broke on my car too(The battery tie downs usually don't survive 20 years so people just sit the battery in there and it breaks that little ground when you turn too hard) My battery runs fine without that little ground. I would suggest buying a battery tie down from a jy, and possibly replace that whole negative cable that I believe goes down to the transmission
        Click For MRT
          wouldnt doubt that autozone battery is shitty. i had 4 within 1 year. never again will i buy an autozone battery. honda ftw. and its cheaper too.
          COUPE K24
            I would fix the ground wire. If that doesn't help then I would get your alternator looked at.
            I don't know a single thing about mechanics, but I can take anything apart and put it back together from memory.
              Have autozone run a test on your electrical. They do it for free. They'll wheel a big ass box out to your car check your alt, batt, starter, and check for drains all with there little toy.... and its free
              My 90 coupe Mr thread....
              http://www.cb7tuner.com/vbb/showthread.php?t=178452
                Originally posted by SPLCB7 View Post
                Have autozone run a test on your electrical. They do it for free. They'll check your alt, batt, starter, and check for drains all with there little toy.... and its free
                Ditto
                An easy check/fix is to make sure the terminals are clean of any corrosion and tightly secured because if they say the battery is good, something is preventing it from taking a charge while the car is running. Bad alt. ideally should through the CEL and if the alt. was shot your car would eventually on you after it was started.
                  If you want to isolate the battery from your problem then I suggest disconnecting your battery terminals after using your car ( when you dont use your car for an extended period such as overnight).
                  Then reconnect before starting. If its weak then the battery is faulty (cannot hold charge) if it starts ok then its your car thats the problem (draining the battery un necessarily)
                  Rides:
                  Accord
                  92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
                  96-AUDM-2.2 VTiS- Heather Mist
                  CR-X
                  88-JDM-Si- Black
                  CR-X Del Sol
                  92-JDM-SiR "Transtop" Motegi Edition - Silver
                  95-JDM-SiR "Transtop" Daytona Edition - Silver
                  92-JDM-SiR "Transtop" - Black
                  Prelude
                  91-JDM-Si-4ws "Si States" - Phoenix Red
                  91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
                  91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
                  91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
                    check your ground and make sure its clean. No corrosion. Check your ring terminal that you secure to the battery. Make sure it is cleab and not cracked or warped from being tightened too hard. Ive had to replace mine before. Check the posititve lead that goes from the battery to your alternator and make sure it is connected to your starter properly. And like others sort of mentioned. Make sure theres nothing killing your battery like an after market alarm etc. The smallest things can kill a battery.
                    Everyday is one day closer to completing my cb7 <3
                      start car.while running unhook battery.if car stays running than the battery is bad.if car dies then alt is bad.
                      my new turbo build
                        sounds like it could be the alternator.... try disconnecting the battery while car is running... if it dies could be alt going out....
                          Does your battery light on the dash come on while the car is running?
                          Sounds like your alt is not charging and the car is just running off the battery and the constant starting/stopping and running with any accessories on is killing the battery.
                            Don't disconnect the battery when the engine is running.
                            '94 CD5 EX F22B1 Automatic
                              Why not start with that broken cable?? It was put there for a reason!
