Transmission vs Sensor problem (auto)
    First transmission gave out b/c it had a hard time changing gears when speeding and coming to a complete stop. Took a chance with another transmission from the junkyard without a sensor. Used the old sensor from the transmission that gave out on the transmission I just bought.
    Now I actually have to shift gears like a manual tranny but its from D3 to 2(back and forth) to get the car moving. When I'm breaking coming to a complete stop there's no problem with the transmission. I also tried putting " Trans-X .. its like fluid additive to help it change gears smoother .. but no significance results
    Any suggestions on what I should do , my first thought is actually replacing the sensor with brand new sensors ... anybody ran into this problem before ?
    how about running codes on the TCU to see if there is an issue there. Instead of doing a bunch of work.
    It may be easier than you think.
    Retro!
    Hater
      Im haveing the same issu but its my tcu that is bad. It wouldent hurt to open it up and see
      If any thing is burnt.
      Car safety checks
      Fluid Capacities
