How do i conect a Air fuel ratio gauge, i know it goes to the o2 senor and ecu but how do i wirer it ? on the gauge i have pos + and neg - wires and then a green wire?
Air fuel ratio gauge ?
Originally posted by jdmboi type s View PostHow do i conect a Air fuel ratio gauge, i know it goes to the o2 senor and ecu but how do i wirer it ? on the gauge i have pos + and neg - wires and then a green wire?
Green goes to the wideband
Positive to ignition
Negative to ground
My 5.7 LS1 Holden Ute
you should be able to find a grommet to run the wires thru the fire wall. if you do end up having to make a hole make sure you put simething around the edges so you dont have bare sharp metal on your wires. i was lucky enough to have a grommet on the pass side that had nothing running through it since i have a dx with no ac...
Ride List
1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
Hooking a AFR Meter up to the stock oxygen sensor, gives you nothing more then a light show. The only time you would wire directly off the ecu's connectors is if your running a "chipped" ecu, that knows how to understand a wideband o2, and you want a gauge.
Otherwise there are aftermarket oxygen sensors / gauges that can provide a narrowband signal to the ecu, and a wideband signal to the gauge/datalogger, or wideband to both.
Originally posted by jdmboi type s View Posti have a wideband afr guage but i just notice my h23 doesnt have any o2 senors !? ..can anyone help?
You can't hook the gauge up to nothing, And I find it hard to believe that it doesn't have an O2 sensor.
Also the sensor need top be wideband, not just the gauge.
Originally posted by jdmboi type s View PostYeah no o2 senor, i checked everywhere , and theres no hole for the o2 on my dc sports header ..so can i just wire it to the ecu ?
Is the engine check light ON?
Also as we keep telling you - Its a waste of time connecting it without a wideband sensor anyway.
are you running a chipped ECU?-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
