How to remove/clean EGR valve
    Hi All
    I want to remove my EGR valve so I can clean it. I've read on here before that there is allot of carbon build-up inside the EGR valve. If this holds true, well I would definitely want mine to be clean.
    How do I remove it? I see these wired-flanged metal clips that secure the rubber piece, but I can't figure it out. I've tried searching , but I can't find details. Thanks All
    Took me 10 seconds to get both links.
    Here you go!
    http://www.cb7tuner.com/vbb/showthre...ghlight=EGR%2A
    And another!
    Stop being lazy.
      Here is another from google.
      ::edited::
      ahh damn nvm, it was in the first link from Jarrett.
      Here a video with some info http://www.youtube.com/watch?v=vLU6MeRFdBY
      92 DX Sedan - Auto
        Here you go!
        And another!
        Stop being lazy.
        Thanks for the links man, I really appreciate it. And for the record, I couldn't find any links. I did look. I was NOT being lazy.
          ::edited::
          Thanks you, too!
            Wait a second.. This ain't what I'm looking for. I want to remove the EGr Valve, not ports.
              A 10mm socket with a 6-inch extension and 3/8"-drive ratchet and you're gold. Expect a CEL though.
                Even after I replace the EGr? Could I just reset the ecu??
                  Sorry, I forgot the focus of your original question. Yes you can clean it easily and put it back. As long as everything is hooked back up correctly you won't have any codes.
                    Awesome. Thanks for your info Jarrett
                      A wobble extension and a reg. 12mm (not deepwell) will do the trick since the "hat" sorta extends over the nuts, it's not a straight shot.
                        Yeah, I noticed. I'm just going to use the wobble.
                          Dangit! 12mm and not 10mm. You got me.
