f22a6 turbo
    f22a6 turbo
    i am planing on boosting my a6 but i want to know how much boost could the stock block hold . also i would like to know what would be a safe setup for a everyday driver.
    Its not about how much boost its about how much hp and the most i would push on a stock f would be 220
      thanks
        Regardless of how careful you are, you will inevitably break a ringland sooner or later. The stock block will not hold for long.
          Oh wow guy, I just put over 220 hp on my V12 twin turbo polar bear up ere in Alaska eh?
          My stock block hasnt broke yet at all.
            8-10 pounds on stock internals will be safe for a everyday driver
              That really depends on the turbo. 8-10lbs might be 200hp with a small turbo, and 300hp with a larger turbo. Big difference.
              However, yes... 8-10lbs is the general rule of thumb for the most commonly used turbo sizes, and 200-250hp is about what one should expect to see.
                lam looking to get about 280whp or better
                  Stock block... definitely don't expect that to last long. I would strongly recommend upgrading the internals if you want it to last.
                    i am going to upgrading the internals
                      Then that's not called a "stock block" build... and your wallet is the only thing that will be limiting you. You can run as much power as you want.
                      For a stock block setup, there are too many variables. The 220hp estimate above is probably accurate if you want to drive and beat on it daily.
