Ok guys I have a problem... After I did the h22 SWAP I also did the auto five speed and now the fuel pump isn't priming. Does any1 have an idea what it could be
h22 swap w/ auto to 5 speed
You've done so much custom work that it's nearly impossible to even guess at what the problem may be with the information you gave us.
Generally, the fuel pump not priming would point to the main relay as the most likely culprit... but with everything you've had to mess with to do your conversions... it could be damn near anything.
