HP boost?
    HP boost?
    ok so i know i can get a f22a6 ecu cam and itm to boost my hp on my f22a1 and would dsm injectors work with that setup cuz i heard i can add turbo dsm injectors is that possible?
    you can but it wont do any good. if your cars not tuned for them they wont do anything the stock ones wont.
    COUPE K24
      so the injectors wont add i lil hp to it?
        nah. not unless you have a need for them like boost or a built n/a motor.
        COUPE K24
          ok so im getting a f22a6 itm for 25$ a ecu for 25$ and a cam for 13$ and i will be uninstalling them 2mm would i need a special tool for the head to get the cam out?
            shouldnt need anything special but basic hand tools. 10mm,12mm, and maybe a 14mm.
            COUPE K24
              ok and what else can i get for it i have a 4-2-1 header already so i dont need the a4 header
                step the intake manifold up to a h23. youll be glad you did now. if you cant find one, you can always get the a6 now and swap a h23 upper plenum and tb on later.
                COUPE K24
                  ok i know were i can get a h22 or h23 itm and tb for the same price
                    make sure you get the f22a6 or h23 lower intake. h22 wont fit. atleast the runners wont.
                    COUPE K24
                      Just to clarify on the injectors... more fuel does not equal more power.
