Custom intake??
    Custom intake??
    was looking around at cars on here and came across marcusv8thunder's accord i noticed he had an intake by his front bumper lights. did some research and its called a pipecross air intake. my question is whats the difference between a pipecross and cold air intake. been doing research on pipecross but not getting to much. any info would be great!! THANKS
    Which one is better?
    Here's a simple test:
    Have someone drive you down the interstate, be sure to be in the passenger seat.
    First experiment is to crack the window and breathe.
    Second experiment is to stick your head out the window and breathe.
    Which experiment yielded you the easiest breathing?
    The only benefit of that "pipecross intake" would be when you're on the dyno and no air in getting under the hood.
      oohhh i see so kinda just for looks and not made for Daily drives
        The front of an Accord is very aerodynamic. Air will flow around/over that small of a space. It will not add any power or air to the engine.
          at high speeds there would be a pretty solid high pressure zone in that area. i bet you would have more power and efficiency at highway speeds. at lower speeds i think it would slightly retard the intake's ability to breathe. but at any speed it will be forcing rain right into the engine which would not be good for a DD. this system might be better for a chump car or LeMons car.
            It would not force air in at high speeds, as Josh explained above.
            As for rain, that duct wouldn't run straight to the intake. It would simply run straight to the filter. It would offer no more danger than a normal CAI setup.
