P12 ecu plug n play
    P12 ecu plug n play
    i was told that the p12 ecu is plug n play and would add a little more power is that true
    If you have an F22A1, yes.
      Yes it is plug and play. I just put one in my car but you do not feel a difference
        what about the f22a4 does that do anything for it
          Yes i believe so but its not a noticeable difference.
            yes its a PT3 AZM ecu
              okay was just making sure it was a pt3
                so is it worth getting the ecu or should i save my money for something else
                  If you plan on upgrading the engine i would get it. It is easily chippped and tuned. And it is a good place to start upgrading.
                    if i plug it in is there any benefits at all like mpgs or hp. im all stock besides a short ram air intake
                      You will get a few ponies but nothing that you can tell. Mine throws codes because i have an automatic and i put in a manual ecu. I believe it helps more on bottom end than top end.
                        You will feel a diffence. Power band is a bit more even.
                        Since you have a cel your probably not running at 100%
                        wat?
                          what do u mean i have cel i dont get it
                            do u mean a check engine light
                              if so i dont have any codes and my check engine light is not on i just went to the honda dealership last week and they tried to pull codes but they didnt get any.and i just put a new fuel pump and dizzy,main relay,ignition switch and so one
