Moog Ball joint installation question K90490
    Hi guys, I bought MOOG upper ball joints (K90490), the instructions that came with them aren't very clear of whether you press them in from above or from below, I couldn't find anything on the web. My suspension is stock, car isn't lowered or anything.
    Thanks guys, I appreciate it.
    1993 Honda Accord EX
    These are the ones I'm talking about:
    http://www.autopartswarehouse.com/sk...Front%2C+Upper
      Question: how do you know if the ball joint is ruined?
        If there's play n the joint, or if the boot is torn.
        Honda doesn't sell the upper ball joints separately from the control arm, and I assume they do that for a reason. Pressing the old joint out and the new joint in can cause a good deal of stress on that relatively thin band of metal holding it in place. I know it costs more... but buying the entire upper control arm assembly from Honda is the best option.
        Otherwise... press out, press in. Just be careful to use something (like a socket) to evenly distribute the pressure along the outer edge of the ball joint. DO NOT press on the center of it, or you will damage it.
