I have a 92EX A6 with 300,000 miles, car ran fine only used about 1/2 quart of oil every 10 days or so. Over Christmas I put on my new intake set up. This mod consists of A6 intake runners with double stacked IAB's that are operational, with a H23 plenum and TB with a Bisimoto heat shielding intake gasket.
I put everything back on and started the car It ran beautiful. Idles at 800-900 after warm up. It was pretty cold outside so I opened the garage door to start the car. I thought I was just seeing hot exhaust in the cold air, so I paid no attention to it. I shut the car off and checked every thing over before I went on a test drive, the oil was LOW....I don't let THAT happen ever I check my oil weekly. I put in 2 qts and now the oil level is FULL to the top mark on dip-stick. I took the car out and it ran fine I sped up quickly from 10 to 40 and I thought I could see a little smoke as I accelerated. I pulled out on a main street from a stop I then accelerated quickly as if to pull into traffic....there was no traffic. Under the street lights all I could see was SMOKE behind me. Under acceleration and at every shift I was fogging the entire lane with smoke, drove 2 miles to get home. Pulled into the garage and checked the oil and and the engine BURNED 2+ quarts. I am LOST..... I don't know what this could be I don't believe the swap caused this problem.
The only other work done at this same time was heater hoses replaced and O-rings on the transfer pipe on the back of the motor. I need help.
Thanks and Be Well.
HAPPY NEW YEAR and be safe
Thanks and Be Well.
