What Mpg Are You Getting?
    20/21 mpg HIGHWAY.
    h23 IM, automatic, CEL, and S light flashing (lock-up clutch not engaging)
    prolly worse ive seen with nothing being wrong with the motor physically (i.e. leaks or bad compression)
    -Tyler
      Mine are always mixed i did the math a while back and figured out i was getting 24mpg so i put 3 gallons in my car hoping id get around 75 miles to get to school and work for a couple of days. there are times i do and times were i i barely make it to 50 and im not really driving any more aggressive or flooring it more i drive the same so idk what my exact numbers are lol
        I get around 140 miles to a full tanke of gas. after full tune up.cap ' roter ' plugs ' wires ' o2 ' oil ' oil filter ' feul fillter and seafoamd it . Still 140 to a tanke. Thats around 10 mpg high way.
        Car safety checks
        Fluid Capacities
          Have a look at my write-up. Hopefully this will dispel all the questions.
          http://www.cb7tuner.com/vbb/showthre...03#post2930603
          Original-Owner 1991 Honda Accord
          2005 Acura TSX 6MT
          2010 Mazda Miata Grand Touring
            Originally posted by tm123 View Post
            20/21 mpg HIGHWAY.
            are u serious.....i usually get that on city only....!!!!!! mabye o2 sensor
            VS
            Mercyboy: I rather lose by a mile because I built my own car then win by an inch because someone else built it for me..your car is your story, so don't let someone else write the book!
            MERCYBOY THREAD:http://www.cb7tuner.com/vbb/showthread.php?t=158241
            1990 RHD Honda accord si CB3 Canada http://www.cb7tuner.com/vbb/showthread.php?t=196287
            MY CB7 ON YOUTUBE: http://www.youtube.com/watch?v=CJID_IxwiNY
              I wonder if his CEL is throwing off his mixture. This has happened to me a few times (Especially code 43, O2) and there is nothing worst than doing a fill up only to see you got 20-25mpg.
              "There is nothing wrong with you that an expensive operation cannot prolong."
                the cel makes it run rich i believe.
                i am throwing code 12 for EGR because it is not there.
                -Tyler
                  400 miles on a full tank
                    i get a combined of about 25mpg and i got kind of a lead foot
                      Rich means more gas is going through the system.
                      I just did a quick search on another forum and lots of people report that not having your EGR gives them less than 20mpg and after hooking it up, it went back up to 30mpg.
                      Can you hook it up and see if that fixes your problem? You could also build a plate to go in between the EGR and the post hole, basically eliminating the EGR but taking the light off your dash.
                      I also have a buddy who has a skunk intake that does not have a port for the EGR, he just has his plugged in but zip tied to the intake so it does not flop around. That also eliminated his CEL light.
                        20/21 mpg HIGHWAY.
                        I also have the input/main shaft sensor code with the flashing d4 light, and a bad o2 sensor, unhooked because the car needs valve seals, even still with these two codes we get 20-22mpg depending on where we get gas, its a 92 auto EX, f22a1 engine, A6 intake manifold, A4 exhaust manifold, with a intake and 2.5" exhaust to a dynamax turbo muffler. Mind you these are city miles, not much highway driving for us. The TCU is from a 94 Accord EX and it has the original transmission with 305,000 on the odometer. Hoping for a improvement in mileage considering I just did a timing belt, waterpump, balance shaft belt, distributor cap, plugs, wires, accesory belts, B&M fuel pressure regulator, rail mounted fuel gauge intake and exhaust. Really want to clean those egr ports out soon...
