Oil?
    Oil?
    My cousin has a 1991 Honda Accord EX and he wants to know the best type of oil to put in his car for peak performance. Ill listen to anything
    My Baby "CLEO", Slowly Making Her Mine
    5w-30
    wat?
      Originally posted by C91BLX7 View Post
      5w-30
      What brand?
        What ever makes your wallet happy.
        wat?
          Any brand is good as long as it's quality like castrol syntec, mobil 1, etc. Personally I think royal purple is the best. As for Tranny oil if it's auto ONLY use Honda ATF.
          1993 10th Anniversary MRT
          Originally posted by The G-Man
          For that money, yes. But my dick isn't big enough for that shit.
          List of all my cars to date
            You can use Redline D4 or Amsoil ATF as well. Or if your using a rebuilt unit with out oem honda clutches you can use whatever you want.
            wat?
              Its an automatic...so use those??
                Royal Purple I definately recommend and for the tranny Honda ATF or the ones he listed as well.
                  Eh Royal Purple isn't worth the excessive price. Pennzoil Full Synthetic will work good enough at a reasonable price. Also it can be had 5qts + k&n/purolator filter for around 35 bucks at advanceauto.
                  wat?
                    But I heard that once u use synthetic oil you can never change back and use any unsynthetic oil? Not too sure if it's true but something I was warned of.
                      Royal Purple is Synthetic too. You can do what ever you like, you might develop a small leak or two, or you might be fine. Only one way to find out.
                      wat?
                        Unless your engine is going to be under extreme stress, there's really no need to use an expensive oil. Any quality oil of the correct weight will work just fine in an F22A.
                          Agree. If you are not beating the engine up neither is the oil. Quality band oil and filter.
                          Tim
                          '93 Honda Accord EX Coupe
                          F22A6, AT, Aluminum wheels
                          This car is stock @ 128,500
                            Opinions will vary. I recommend either Mobil or Genuine OEM Honda juice. Peace.
                            The Lord watches over me!
                            "Stop punching down on my people!!!"
                            - D. Chappelle
                              I use Mobil Clean 5000 on the DD, change it every 5k miles and consistently get 32mpg. Engine has 257k miles and no leaks. Honda OEM Oil filter
                              member's ride thread
                              91 Accord SE 176k
