The a1 cam is a regular cam and the a6 cam is a wilder cam from stock and gets better rev and acceleration...I ended up swaping my head cuz its a better built head compare 2 the a1 and wit the a1 block you Will be impress with the performance you Will have
A1 and A6 camshaft
Originally posted by cmd cb7 View PostThe a1 cam is a regular cam and the a6 cam is a wilder cam from stock and gets better rev and acceleration...I ended up swaping my head cuz its a better built head compare 2 the a1 and wit the a1 block you Will be impress with the performance you Will have
Both the A1 and A6 cams are "regular". The A6 cam does have a different profile, which makes for a SLIGHT increase in power.
This is great to know. Would have been nice to know when looking for a motor on CL since so many of them seemed to be in pieces and always looked like people had messed with them. So it would have just been a nice little check on top of the engine stamp."There is nothing wrong with you that an expensive operation cannot prolong."
Originally posted by deevergote View PostThe head castings are the same. There is no difference between the F22A1, F22A4, and F22A6 head castings. There is nothing to be gained from swapping the complete head.
Originally posted by cloudasc View PostThere is only one other difference between the a1/a4 heads and the a6, the valve springs are different, its a moot point, but they are slightly different.
Concur?90 Accord Ex, F22A4. Slight fire damage.
Originally posted by H.M. View PostAnd from what I read in the "valve spring" thread, the only issue with using the A4 springs in the A4 head with the A6 cam would be a need to readjust valves 2x as frequently - every 15k miles instead of 30k IIRC.
Concur?
Originally posted by cloudasc View PostI don't think its that extreme, not if your only reving to 6.2-6.3k rpms all the time (thats where my auto shifts when WOT [I also have Bisi Springs]), if you were taking it up to 7k all the time, or using a reground cam checking/adjusting them every 15k miles would probably be a wise thing to do.1991 LX Wagon
