Window problems
    Window problems
    My drivers side window is messed up. Either the regulator or moter, maybe both. But it's halfway down, anyway I can get it up with the motor out? It is a pain seeing as how it's getting cold and raining some. Sometimes it works an inch or two at a time but past couple days hasn't moved. Any help is much appreciated.
    Open the door and have someone push the button up, and pull the window (gently) with the motor pushing the window up. My 2005 accord did the same thing. Get the motor and regulator replaced soon.
      biggest reason the power window regulators fail is the run channel is not lubed.
      the extra friction from the dry rubber on the glass will usualy brake the plastic on the top of the regulator first.
      this is why you see some guys with the window down 1/2"
      i recomend a good quality silicon based spay, use the straw to shoot it in the run channel with the window down,
      silicone spray on all the rubber seals will keep them soft and is a part of a major service.
      Budget Street is offline working in the shop
      drop the mouse and pick up a wrench
      Good for you. You don't even know how to spell VTEC.
