What Tire sizes are most cb7s running
    Its also very intersting that honda doesn't show an exploded view of those two parts together which didn't help me understand "The Grande Picture"
    Thanks for "schooling" me!
    And for both of those parts from honda... is over $300!
      yeah i find it quite strange they are in different sections although one part is bolted to the other and nothing else. Why its in " combination meter " is really random to me.
        The tires that came with my car are 215/45 R17
        Speaking of VSS, I definitely need a new one.
        ||91 Accord EX|| All of my images are hosted courtesy of imageShack.com
        Door-Sensor fix (DIY)||Interfacing Arduino to Power locks
        RICE = Race Inspired Cosmetic Enhancement.
        "The greatest advantage of speaking the truth is that you don't have to remember what you said." - unknown
        "That's the funny thing about parts that break... they're never broken until they are!" -deevergote
          Ok well I just swap the front tires (205/40r17s) with 215/45/r17s. And so far I'm very pleased. The 205/40s where very rough and provided very little protection for the many pot holes down here. And the 215/45 really grip the road. I big into cornering, thinking about across... I think this combination Is a step in the right direction.
          So now 215/45/r17s in front and 225/45/r17s in the rear. Ps this is with a 2" drop and no rubbing!!
            Um... we don't drive corvette's, and our cars are fwd, so why would you put larger tires on the rear?
              Have you run the 225/45R17 in the front? I was just wondering if those would rub. I have 215/45R17's and they have no issues. Any reason you went with different size tires on the front vs the rear? Rubbing issues?
                The rims came with tires. 225/45r17 rear 205/40r17front. Not my choice. Imagen how it looked before I swapped the front tires.
                As for performance, It's awesome. I pull corners very tight and never loose grip. And think about this; when you pull a corner hard in a front wheel drive car with a pretty fat ass the rear tends to get loose. A wider tire in the rear could actually help stabilize the car right.... Just my own Opinion.
                  Thats what you call oversteer, our cars are the exact opposite, we suffer from understeer. There is also the saying about always putting the best tread tires on the rear though.
                    I have 195/60/15 on the front and 195/65/15 on the rear. My rears are noticably larger in sidewall height and looks stupid, but does give the car a slight raked look.
                    See sig pic.
                      See sig pic.
                      I should have said "wider" tires in the rear. I was referring to the contact patch.
                        I understand what you were talking about, but I was making note that I hate the way my car looks and sits at the moment.
                        On a FWD car, I'd rather run the same size of tire all around. Stagged looks stupid, especially wide tires on the front and noticeably smaller on the rear.
                          The only time the staggered look is good, is when you put on some slicks, and toy (narrow) tires in the rear for drag racing.
                            On a FWD car, I'd rather run the same size of tire all around. Stagged looks stupid, especially wide tires on the front and noticeably smaller on the rear.[/QUOTE]
                            The Hight of my car is equal with no rake. And the rear is slightly wider than the front, so no stagged look either.
                              I feel you can run different size tires as long as the side walls are the same Hight
                                or on an older hot rod like a 23 T or similar
