Main relay.. what problems can it cause?
    That's a distinct possibility. I'm not terribly knowledgeable about the fuel pump setup, as I've never changed one myself... but that seems like a much more likely explanation for your symptoms.
    That also has me wondering if maybe your fuel gauge is inaccurate, and you're simply low on gas.
      I am hoping this will at least lead me into the right direction. The car does have gas in it now. The first time the car started acting up, but not stalling, the gas gauge was under 1/4 tank so it may have been going empty then.
      I have a friend who is a pretty good mechanic who used to race integras on circle track and i keep bothering him about this problem too and he thinks the main relay might be a possibility (if it powers the sending unit), a common ground with issues, or just a power lead problem.
      '94 CD5 EX F22B1 Automatic
        Change the relay.. (get correct new one don't Fuk around with soldering and a "friends" just man-up and get one). Spend some bucks and fill the tank too, so you have no doubt about "if" the car has no gas as shown. If after all that and it still doesn't work, check if the fuel actually gets to rail.
        Old wagon - Silver '92 LX Wagon - Steve (Shadow)- STOLEN ON LABOR DAY 2012
        New wagon- White '92 LX Wagon on 1/3/13 (Frostbite)
        2000 EX Coupe - Joe -
        www.AccordWagonClub.com
        My Facebook Site - ACCORDOBSESSION
          i wanted to mention that the car has spark all of the time... still no fuel or gas gauge though.
            With no gas gauge, I'd definitely go after the sending unit. I'd start at the gauge and trace the wiring back.
              rechecked the ground from the lines going to the gas tank and it was loose. fixed it and the gas gauge went right up and the car fired right up too... hopefully this is a resolution and the plugs, wires, cap and rotor fixed the misfire because that hasn't been an issue since those parts have been installed.
              thanks guys
                Good eye. Hope that's the end of your problems.
                92 Honda Accord LX - Sold
                2005 Nissan Altima 2.5S - Sold
                2007 Dodge Charger SXT
                  Originally posted by SilverShadow View Post
                  Get a new relay and then if the car still does all that....then go with their suggestions.
                  Might as well put a new motor in and hope it fixes the issue
                  Retro!
                  Hater
                    can the main relay go out at anytime?
                      Yes. Any part of your car is capable of failing at any time. Nothing lasts forever.
                        ok thanks. this may be whats wrong with my car. ive been trying to get a answer since this morning but nothing yet. if you can help me out that would be awesome. ive been reading similar threads since this happen (which was saturday) but really cant come up with a solution.
                        http://www.cb7tuner.com/vbb/showthread.php?t=184357
                          You already have a thread about it. you don't need to direct people away from this thread.
