Best Spark Plugs And Wires To Use
    NGK plugs and wires for me....
    deevergote- Thx for that info... Didn't know about the Sumitomo wires... Interesting...
      I'd go NGK Iridium plugs and NGK wires all the way. The ignition is great. MSD has great selection as well but thats for a more upgraded motor no real advantage for Daily driving
        I use NGK plugs and Magstar wires... Performs really well
          I did a slight test between my oem spark plug wires and some cheapo autozone silicone run of the mill spark plug wires. The resistance on the cheapo wires was much less than my OEM spark plug wires. I also looked at some NGK wires and they are pretty much the same resistance as the cheaper autozone wires.
          I hope i didnt bring the topic off but would this mean that NGK wires and some off brand generic silicone wires are the same? Maybe just quality of material is different and one may last longer than the other?
          Is it better to have less or more resistance on a spark plug wire?
          As for spark plugs i stay with NGK just because they are affordable and give consistent quality results.
            The tests I've seen have shown the OEM Sumitomo wires to be the best of all. I've never heard that NGK wires didn't work well... but I suppose it's possible.
              Oh, if i made it seem like the NGK wires didn't perform well i didn't mean to do that. I was just trying to compare resistances to see if it was just hype or performance. If the resistance is just a small difference is it worth getting the more expensive brand? I don't know what other variables there are when trying to pick spark plug wires.
                OEM all around
                Especially when dealing with ignition components
                  Do not buy Carcraft wires. They are terrible materials and #3 barely even fit. The connectors weren't even oem style. They were so awful I ended up putting the shitty olde wires back on.
                  96 mx-6, needs work...
                  91 accord lx sedan, needs work...
