stutter low rpm neeeeed helllpp
    car stutters at low rpms and seems like a miss anyone have any clue whats wrong?
    CEL is on where is the plug to jump it to get code?
    Right above the passenger kick panel
      What do you mean by "stutters". What RPM is "low RPM"?
      The info regarding checking the CEL code can be found in the thread marked "read here first" (which you obviously didn't.)
        have you messed with your dizzy at all. if so it might need timed. and it could be mutiple problems how does it stutter. does it stutter all the time? it helps if you give more discriptive about what its doing its hard to diagnose a car over the internet.
          Car seems like it wants to shut off ramdomly. The dizzy was changed resently it happens alot wh en going up up hill. It also has a ruff idle
            well did you do it? and if you did, did you put a timing light on it to make sure everything was timed right? if your car is out of timimg it will run like crap
              When i tried to get the codes for the cel the abs light came on and blinked 4 short then pause then 2 short. The cel wont blink only the abs.
              I'm going to try to check the timming. I marked the dizzy when removed maybe i got it wrong.
              But its weird it will do it when you first start it for about 1-2 seconds then it will do it randomly while driving.
                Don't touch your dizzy, and your cap & rotor won't cause a stutter, signs of a bad dizzy or cap would be more into how long will it take your car to start or even a missfire during start up...
                Timing , don't adjust it, running too lean or too rich won't make it stutter just burn fuel, and horrible MPG.
                Most likely and I mean 80% of the time its your O2 sensor , it might be going out and throwing a CEL......signs usually show bogging stuttering or hesitation during low or.mid rpms 1.5-4.5 and would not go away till you let off the gas and gently slowly press the gas again, almost hearing backfires while it occurs....
                If it ain't your Oxygen sensor then please check for spark in your wires, better than checking the cap or dizzy plus messing with the timing , I don't care if you mark it , its still going to be way off so always use a gun if you decide to just remove it bro.
                .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
                  I was thinking it was the o2 sensor and was going to replace that before anything. I am getting bad mpg.
                  Spark from dizzy is good.
