Rough Idle
    Rough Idle
    I changed the front brake lines yesterday, Ten I test drove it and everything it was fine. Then like 30min later I went to the store but when I started my car it had a rough idle (500-700) . I checked the spark plug wires, oil, coolant and everything seems fine. My dad thinks that its bad gas and I had like 3-4 gallons left in the tank so he thinks that my car is sucking in the bad gunk in the gas filter. I added some fuel injector cleaner today and the rough went up now its (800) yesterday morning it was (900-950). When i drive its kind of rough but as I go up in gears it drives perfectly fine (Automatic). Thanks
    Adjust your idle (the instructions are in the stickies) and see if it still does it. Did you do the lines in the wheel arches or all the lines in the engine bay?
      Just the 1 line in the wheel arch that connects to the brake caliber
        That shouldn't have anything to do with it. If you were active in the engine bay, you could've hit a brake line. That would have messed with you idle.
          Yeah I know, thats like why Im like WTF. I didnt touch the engine bay. Bu like my dad said I was driving low on gas and maybe it sucks up some stuff from the gas filter
            It will, but I usually drive till almost E. I used to fill up at 15.5 gallons, I've generally moved it down to 14.
            I changed the FF because I was bored. I think it's an idle issue (fuel filter would still give you issues at speed), but if you want to change it, feel free.
              You doing your brakes and a rough idle arent connected, just sounds like a coincidence. Are you gettings any CEL's? Have you checked your plugs/wires/dizzy?
