I have a 92 accord sedan auto f22a1 and im havin some speedo trouble my speedo is off by 10 miles at times an off by 5 miles at times an im runing stock size tires on it will the adj coil overs have any afect on my speedo an my 2nd problem is my torq converter lock up isnt working rite it doesnt kick in unless u goose it at cruisin speeds an as soon as i let off or my speed levels out it kicks back out and ive changed my speed sensor an tcu any help wuld b awsome thanx in advance
Speedo an torq converter lock up problems
Originally posted by Leon_C. View PostI have a 92 accord sedan auto f22a1 and im havin some speedo trouble my speedo is off by 10 miles at times an off by 5 miles at times an im runing stock size tires on it will the adj coil overs have any afect on my speedo an my 2nd problem is my torq converter lock up isnt working rite it doesnt kick in unless u goose it at cruisin speeds an as soon as i let off or my speed levels out it kicks back out and ive changed my speed sensor an tcu any help wuld b awsome thanx in advance
How did you come to the conclusion that the speedometer was inaccurate?
Do you have a d4/ s light flashing?
I'm not quite sure i understand your torque converter problem. So it locks up at cruising speed but unlocks when you start to coast? How are you verifying its not locking up?
srry bout the pic dk y its so big and the torq converter lock up does not kick in at cruising speed the only way it will kick in is if i press the gas dwn a little harder than it will just kick rite back out again an i knw my speedo is off because at 45 mph im passing every one on the hwy an its runin at close to 3000 rpms
and no my d4 light is not flashing
any1 have any ideas
