stuttering
    stuttering
    while i was driving my cb stuttered out of no where and after a little while my engine light came on. Does any one know what this could be?
    Follow this thread and tell us the code, then we can help.
    http://www.cb7tuner.com/vbb/showthre...pull+CEL+codes
      When the car stutter, were you pushing the gas pedal to speed it up? If yes, your EGR ports and valve might be blocked. Check the codes first.
      Also when did you change your fuel filter?
        so the code i got is 43. Fuel supply system and its the only one it has
          Thats your 02 sensor, replace it with a Denso or NGK/NTK ONLY, not Bosch.
            it should be one of the following your dizzy pluggs injectors of gas line start with some high guality injector cleaner. if you know how to take a dizzy apart just get the rotter button and clean the dizzy out
            underground Society 757
              WTF? He just said hes throwing a CEL 43, o2 sensor. Theres no need for this suggestion, its clear he needs to replace his 02 sensor BEFORE any of your suggestions.
                Code 43 is an o2 sensor code (as stated above), and a bad o2 sensor will cause stuttering, bogging, etc.. whatever you want to call it.
                  hey i was just trying to help i had the same happen to mine and it wasnt the o2 it was my dizzy than my second cb it was my pluggs going bad.
                    i know i replaced one last week and it still studder thats why i said try the other things also if that does not work
                      If the o2 sensor doesn't fix the problem, then yes, your suggestions are good ones. I just want to make sure the guy takes the proper steps before tearing into his car. 43 DEFINITELY means o2 sensor, so that is step #1. If he messes with other things first, without fixing the known problem, he may just create more problems in the process!
                        This is what you said the first time, you said it should be one of your suggestions, nothing about it being the o2 sensor.
                        Its one thing to add your experience, but it clearly looked like you were contradicting the correct suggestion with your own. We just dont want people going out and spending money on something thats not going to fix the issue. The ECU says hey fix your damn o2 sensor, and you are telling him to clean his plugs, get new wires, and to tear apart his dizzy. Thats why deev and I said something.
                          Cool thanks guys ill I'm going to change that. O2 first thing in the morning let you guys know how it gooes
                            Just be sure you can get the correct brand. Most autoparts stores will give you a Bosch sensor... and even though they're made for our cars, they don't work properly.
                              remember NO Bosch, ONLY Denso, NGK/NTK, cant stress that enough.
                              edit.... stay outta my head deev!
