Yesterday I was going to start my car and everything was right ,but it seemed like it just died when I started it. All the electronic stuff was working ,but when I started it it was on for maybe half a second then turned off. Why is this?
Car acted weird when I tried to start it.
Did you clean, adjust idle or some thing else? I pulled my fast idle valve electronic connector and cleaned that. Put some contact grease in there and made sure the connector is good on it. Never happens again. However, I don't know if that is the cause. I check the TPS and the voltage seems good. Not sure if you have a TPS problem it would be more consistent.
But does it seems like the cranking is weak and didn't want to turn over? If you keep your hand on the ignition and keep cranking it will turn over and you have to keep your foot on the pedal for 10 seconds to keep it idle high. Then the problem doesn't occur again for that day.
That was how mine happened.
Originally posted by deevergote View PostJust remember... cars don't fix themselves. If something went wrong once, then something IS wrong, even if it doesn't happen again.
I think there is a little ground lug for the computer on the thermostat housing. I would definetly give that a quick once over.We are "Slow and Reckless Racing", LIKE us on Facebook to keep up with our progress.
https://www.facebook.com/#!/pages/Sl...03065806427543
