Originally posted by blk93
View Post
valve adjustment
told bad_dude i would post pics. so------>
this is the valve seal step, adjustment doesn't need you to remove the assembly.
rocker arm assembly off the engine:
this is where the lower seals are seated:
and this is where they actually seal on the engine :
no pictures for the valve adjustment..just follow the youtube video, or your OEM way via any Manual
either way will work, just make sure you do your research and know what to look/feel for
Originally posted by reklipz View PostIt looks like it's going to be in the way of the intake valves. It's hard to tell from the photos, though. Got a shot from the side of the vehicle, and one from the top?
Thanks.
a lot of people have different feels of DRAG ,, dont let it drag a lot but you dont want to make it too tight. Its better to be a little loose than to be a little tight. make sure you are on the right stroke too then check them after you think you are done. If you did it right the car should be a bit quiet not like all quiet.Last edited by 10thAnnivCB7; 06-27-2012, 07:14 AM.10th Anniversary Accord.
05 Audi A4 Ultra Sport 6MT.
Originally posted by 10thAnnivCB7 View Posta lot of people have different feels of DRAG ,, dont let it drag a lot but you dont want to make it too tight. Its better to be a little loose than to be a little tight. make sure you are on the right stroke too then check them after you think you are done. If you did it right the car should be a bit quiet not like all quiet.
Thanks.
cool man ,, i got a bit more response on the throttle but nothing else ,, now i go a whole week on $30 of gas and i drive over 390 miles a week just to and from school ,, hope it works out for you ,, also have somebody there with because when i did mine i forgot to put the alternator ground back on and my car shut off when i was leaving school ,, noob mistake but having an extra set of eyes helps10th Anniversary Accord.
Originally posted by 10thAnnivCB7 View Postcool man ,, i got a bit more response on the throttle but nothing else ,, now i go a whole week on $30 of gas and i drive over 390 miles a week just to and from school ,, hope it works out for you ,, also have somebody there with because when i did mine i forgot to put the alternator ground back on and my car shut off when i was leaving school ,, noob mistake but having an extra set of eyes helps
Now I wonder if I should change it again since it's been a year? My air filter is clean.
Thanks.Last edited by Bad_dude; 06-27-2012, 06:48 PM.
Just readjusted my valves today.
I readjusted to be a little looser. The throttle was not as responsive, but I hope it might save some gas.
Previously I had it with the intakes at 0.009 in. and the exhausts at 0.011 in.
I readjusted to instakes 0.010 in. and the exhaust 0.012 in.
Here's a video after the adjustments. Are the valves still ticking too loud? The video is made after the car has been driven and fully warmed up.
Thanks.Last edited by Bad_dude; 06-28-2012, 09:18 PM.
Originally posted by 10thAnnivCB7 View PostMine ticks a bit but its so quiet at idle ,, ill try and record it tomorrow when it's warmed up and upload it
F22A1 sound.Last edited by Bad_dude; 06-30-2012, 12:25 AM.
