Seals
    Seals
    okay so today I went to the honda place and ask them how much would it b for the three main seals Cam seal, Crank seal, Balance shaft and they told me $100 does that sound right to anyone ????
    Will I hope on favorite web site in the world EBAY and I found a whole set for under $50 including the oil pump gasket and all part numbers match
    is it safe to purchase something like this off ebay or should I go and get the same part for a higher price?
    91 lx that I call Cinnamon
    There are 2main seals and they are front behind crank shaft sprocket and rear main seal behind flywheel, the oil pump seal, cam seal and front balancer shaft seal are just seals, you could buy the ebay ones as long as the part numbers match, just remeber rubber dries out over time and you have no clue how old the ebays ones are. Also hondas front balancer shaft seal should also come with the retainer since honda has recall on f and h series its known to pop out so they give you the retainer which is a small metal bracket which holds the seal in place.
    1993 CB6 Coupe Seattle Silver YR-94M
    Originally posted by Acclude
    4gens are win. It's in the bible somewhere.
    yeah its verse 10.6:1
    Members Ride Thread
    1993 Accord Coupe- Summer ride
    http://www.cb7tuner.com/vbb/showthread.php?t=130064
    1995 Civic Coupe - Winter/DD
    http://www.cb7tuner.com/vbb/showthre...53#post2744953
      yeah I think im just going to go to O'railly auto parts aka kragen but yeah thanks I wasnt aware of the rear main seal ill add that to the list which is
      Cam seal---5.99-7.99
      Crank seal--23.99-29.99
      Balance shaft seal--12.99
      Oil pump gasket or seal---8.99
      Timing belt-------------36.99
      Water pump------------42.99
      Rear main seal------------9.99
      am i missing anything please help
      and aslo the oil pump seal looks like the cam and crank seal is that correct?
        The oil pump seal is called the race track cause it looks like a mini race track call honda tell them the race track if they are knowledgeble enough they'll know what your talking about.
        Members Ride Thread
          something like this
          http://cgi.ebay.com/ebaymotors/Honda...5#ht_617wt_822
            yes sir.
            Members Ride Thread
              91214-PH1-004 OIL SEAL (80X100X10) (ARAI) , OIL SEAL (80X100X10) $12.94 Each rear main seal
              91213-PT0-003 OIL SEAL (28X42X8) (ARAI) , OIL SEAL (28X42X8) $5.48 Each cam seal
              91212-PT0-003 OIL SEAL (40X52X7) (NOK) , OIL SEAL (40X52X7) $6.63 Each or
              91212-P0A-004 OIL SEAL (40X52X7) (ARAI) , OIL SEAL (40X52X7) $6.63 Each seal, found 2 different ones
              91233-PT0-003 OIL SEAL (27X40X8) (NOK) , OIL SEAL (27X40X8) $5.51 Each crank seal
