98-01 Transmission
    98-01 Transmission
    I was wondering if these year accord auto transmission able to work on our year. What are the differences if any?
    My guess would be no but I could be wrong. I think just H23 and 22's work for our cars. Manual that is
    1992 Accord EX Coupe >http://www.cb7tuner.com/vbb/showthre...00#post3060200
    Originally posted by keepinitclean
    I give it 2 weeks before you sell it.
      And also, the auto transmission of this generation of Accord was quite... unreliable
      from wikipedia:
      "Despite the Accord's reputation for reliability, the V6 models were plagued by transmission failures and prompted class action lawsuits against the company (4 cylinder models were also affected, but not to the same extent). This caused Honda to extend the warranties for the 2000 through 2001 models to seven years or 109,000 miles (175,000 km). 1998, 1999 and 2002 cars were considered for extended coverage on a case-by-case basis. No formal recall occurred. In Canada, recall letters were sent out to owners who fell within a certain VIN range; this warranty was later re-extended for some owners to seven years in length."
        Acura as well. The V6 Accords, some 4cyl and TL's and some CL's from 98-03 had horrid tranny issues. I would stick to 90-97.
        Originally posted by Jarrett
          Namely those J series Trannies. We had an 04 Oddy that had that issue.
          The CB7 Collector.
          Team Kindred Impulse Member #3
          92 LX Coupe F22A1
          2013 Toyota Corolla S
          92 EX Sedan F22A1
          Do you really need to make a thread asking if having your car like this /---\ will cause uneven tire wear? Try walking like that for a few weeks and see if your shoes wear funny! (hint: they will.)
            It was a model year thing though. Most of the issues were in anything made from 98-04. Even some 04 and 04 TLs had bad trannies.
              the guy is asking about 4cylinder accord tranny and you guys are replying about the 6 cylinder trannys. 98-01 came in 6 and 4
              the 4 cylinder tranny for 98-01 will bolt up to your engine but the mounts for that year are totally diffrent. so no it won't bolt up to the chassis
              however it may be possible to drill and tap if the provision is in the case.
              i would suggest a good used 90-97. or as DarkHusk11 suggested prelude up to 01
              check the fluid for color and smell, inspect the drain plug. there is a magnet and some material on the magnet is normal.
              Budget Street is offline working in the shop
              drop the mouse and pick up a wrench
              Good for you. You don't even know how to spell VTEC.
                ...I would stick to 90-97.
                Question answered. /thread.
                  extra sensors and the lack of a kickdown cable causes it not to work, but it will bolt right on
                  Just do what PR CB7 said.
