H22 Axle Issue
    H22 Axle Issue
    Wife purchased a CB9 with a JDM H22a Automatic. When we purchased the car we were told it had a hard shift and noticed it was leaking transmission fluid mildly. Wife climbed up under the car to check out the leak and noticed a gap between the trans and the drivers side axle.
    Can anyone tell us if this was installed wrong or possibly the wrong axle?
    Drivers Side:
    Passenger side:
    KDI CUSTOMS-AUTOMOTIVE UPHOLSTERY www.kdicustoms.com
    Either could be a possibility. Looks like the axle may be too short and it pulled out slightly.Ww
      My f22 automatic did that on the long axle. I think it had to do with the c clip that holds it it. I popped it back in and its ben fine ever since but I am planing on replacing it because I didn't like it and It is going to need boots.
      I have driven like 500 miles after popping it back in and its ben fine
      Green EX http://www.cb7tuner.com/vbb/showthread.php?t=176536
      93 SE http://www.cb7tuner.com/vbb/showthread.php?t=210486
        The trans axle seal is bad, needs to replace it.
        Checkout my MR: http://www.cb7tuner.com/vbb/showthread.php?t=165984
          The axle seal holds it in?
          I thought my axle seal was bad and when I was going too replace it I saw it came out. I replaced it anyway.
            I went to the junkyard and grabbed a snap ring off an accord axle and a prelude axle. I put it on the drive axle and slid it into the transmission. Issue now is that I can not get it to snap into the trans. It goes in so far and then it wont go any further. I have tried a rubber mallet, wood block and BFH, remounting in the hub and kicking it and so on. I can not get this thing to go in!!
            Any Suggestions??
              I got the axle in. Put the axle on a spare jackstand to hold it in place and somewhat straight. Hammered on the axle with a rubber mallet and BOOM she snapped in!!
              Thanks for all the advice!!
