3rd gear grind help
    3rd gear grind help
    I've looked around a bit and I cant seem to find anything, so if its there a link would be awesome. I have a 92 LX 5 speed, and I have changed the fluid very recently.
    My tranny grinds going into 3rd, and 3rd only. I have a DIY short shifter and the tranny grinded before the mod as well. It only happens if I try to shift fast, semi-fast, but if I pause for a half second it goes in fine. I wanted to know if there is something I can adjust to get rid of the grind. Thanks in advance.
    Yeah, you can fix it. Just remove the transmission, open the case, take everything out, and replace the synhcronizers.
    In other words... nothing short of a rebuild is going to fix it. Use some GM Synchromesh Friction Modified fluid in there, and it might help a little bit. Nothing is going to fix it other than a rebuild, though. Just go easy on it.
      Thats exactly the answer I didnt want, lol. The local O' Riellys is trying to tell the Valvoline Max life fluid is equal to Honda MTF, says its due to them using the same friction additive. Any ideas or thoughts on that? And Im sure I know the answer but, Is the Penzzoil Syncromesh thats made for GM cars the same as GM Syncromesh?
