Whats up guys. I usually just lurk but I need some help. I got a H22 swapped cb7 from a buddy of mine. Story is he has too much money and has too many toys and got frustrated with the CB and just let it sit. There was nothing majorly wrong with it outside of a grumpy tranny and little stuff (fuses, bulbs, etc). So I cleaned the car up and began fixing everything. So I saw it was throwing a code for egr and knock sensor. Fast forward to last weekend and I finally get around to putting a new knock sensor in (idk why he didn't put one in to begin with....its not like him to half ass shit). So I screwed the ks into the engine, made a pigtail (all soldered and shrink wrapped), and pinned it into D3. Took the car up the road and after about ten minutes cel came back on. Didn't bother checking the codes again until day before yesterday and guess what....still a code 23...wtf? Go to chang tranny fluid last night and decide to test continuity in pigtail wire and it ohm'ed out fine. Made sure the plug was securely attached to knock sensor, reset the ecu, and took it up the road....same thing. No cel for about 10 minutes and then it popped up with code 23 again.
So my question is wtf am I missing or doing wrong here? This is my first h but not my first honda. Car is running a p13 ecu and the knock sensor is brand new (I guess it could be bad but damn...). I just hand tightened the ks in place when I first installed it (didn't have a socket big enought to tighten at the time) but I tried getting it out last night by hand and it wouldn't budge. If it's not tight enough will it vibrate too much and cause a code to be thrown? Car has innovative mounts and vibrates a lot as is and the balance shafts have been eliminated as well. Could any excess engine vibration contribute to the problem?
Any help is greatly appreciated.
